    Shell extensions not working, solution: reinstall and reboot.
    25 Posts 5 Posters 16.1k Views
      spwolf conexware @davidsplash
      i already wrote what the solution is… you need to reinstall PA and reboot your computer.
      none of your shell extensions will work until you do that.
        davidsplash @spwolf
        seems to be fixed for shell extensions on zip archives using extract to here option. though i stress too many people have had this fault. So is there going to be safe guards against this happening in the future?
            safeguard would be that when it tells you to restart, it means it.
              davidsplash @spwolf
              true but it didn’t not even on uninstalling and reinstalling did it mention this. So this needs to be rectified.
              Also even after a restart this happened only after i decided to unistall and restart delete all reg entries of powerarchiver restart and then install restart did it work. what does that say.
