    Drag&drop issues when preview active
    6 Posts 4 Posters 9.1k Views
    • W Offline
      wohali
      v11.03.04 bug report: When the preview window is open, drag & drop of files from the file browser to an Explorer folder or the desktop fails. Very rarely drag and drop will work when preview is open, but only if the preview window has done rendering.
      Possible fix: put the preview window on a separate thread from whatever handles your drag and drop events? :)
      -Joan
        davidsplash
        what operating system are you running what programs are running at the same time you use powerarchiver how much ram do you have.
          @wohali:
          -Joan
          we will take an look, thank you.
          • W Offline
            wohali @spwolf
            OS: XP and Vista, appears under both. RAM, anywhere from 2GB to 6GB. CPU either dual (Core 2 Duo) or quad core (Q6600). No other active applications. According to Task Manager I’m neither CPU nor RAM bound.
              what are you previewing and how long does the “rending” last? What is rendering - extracting of files that are being previewed?
              • moles42M Offline
                moles42 Alpha Testers
                it only happened to me if I tried to drag from PA browser window to desktop before the image had rendered in the preview window…in all fairness though PA was dealing with pretty large images which took a second or two to display in full.
                Windows 10 Pro x64
                Intel Core i5 3470 @ 3.20GHz
                8.00GB Dual-Channel DDR3
