    Shell ext. - Seperator?
    13 Posts 5 Posters 8.4k Views
    • guidoG Offline
      guido
      The shell ext shows a seperator? I guess this is not correct?
      See image
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
        is that 64bit shell or? weird.
        • guidoG Offline
          guido @spwolf
          nope. 32bit XP
          Intel Core I7
          32 GB RAM
            TBGBe @guido
            I thought the separators were deliberate :confused:
            To separate PA “sub-menu” from other context menu items (note there is one above and below the “sub-menu”).
              can you send me your PA reg file? so I can try to reproduce it…
              Terry - unknown to me, even if true :-). But I dont see that on my computer.
              Now it could be due to installing over older installations as I often clean my PA registry due to testing…
                ivan conexware
                It can also be from some other Windows utility or application since you can even put a separator between some items created with some other application. I cannot also reproduce.
                  TBGBe @spwolf
                  Really - I’ve always had it as far as I can remember. I actually like it and wouldn’t want to lose it - it works for me as I put all PA commands into the sub-menu :p
                  spwolfS MarcFouM 2 Replies Last reply Reply Quote 0
                    spwolf conexware @TBGBe
                    @TBGBe:
                    • MarcFouM Offline
                      MarcFou @TBGBe
                      @TBGBe:
                      +1… I’ve been putting all the sub-items in there as well.
                        TBGBe @MarcFou
                        And you also have the separators :)
                          you should have separators between PA options and other options, but not one between PA options, thats the difference…
                            TBGBe @spwolf
                            … not one between PA options, thats the difference…
                            Oh thanks - that explains it then (to me).
                            Learn something new every day :o
                            • guidoG Offline
                              guido
                              fixed
                              Intel Core I7
                              32 GB RAM
