    Problems with PowerArchiver U3 2009 in Vista 32
    20 Posts 3 Posters 13.0k Views
    • F Offline
      FreeBird
      I just downloaded and installed PowerArchiver U3 2009 (V11.03.03) on my SanDisk U3 stick.
      PowerArchiver itself is running fine from the stick. My problem starts when I try to eject the stick.
      When I close PowerArchiver U3 the powerarc.exe and launcher.exe processes are stopped. Now, when I try to eject the stick with the Eject button from the U3 Launchpad, I got a warning message that PowerArchiver is still running and the Launcher.exe process is started again and is running with 50% CPU load (DualCore processor here). Each additional try to eject the stick results in starting another copy of the launcher.exe process.
      The same happens when I eject the stick with the Windows function “Safely Remove Hardware”. Only in this case I get no warning message that PowerArchiver is still running but Launcher.exe is still started with 50% CPU load.
      Any ideas ???
      FreeBird
      • F Offline
        FreeBird
        It looks like it’s working fine in Windows XP SP3.
        So the problem occurs only in Windows Vista.
        Any ideas ?
        FreeBird
          Thanks FreeBird! Issue was reproduced and forwarded to the developers. We’ll see what they can do about it.
            weird issue, do you use U3 for other software as well?
            F 1 Reply Last reply Reply Quote 0
            • F Offline
              FreeBird @spwolf
              Hi spwolf,
              yes, I’m running some other U3 programs (like UltraCompare UC3, UltraEdit UE3, TotalCommander, Putty, WinSCP, …) without any problems in Windows Vista. Only PowerArchiver gives me problems at the moment.
              FreeBird
                thanks, maybe our SDK is out of date or something, did you try PA 2007 previously on same computer?
                • F Offline
                  FreeBird @spwolf
                  I’m sorry, no. But I could. If you give me a download link for the old version. Is the new license key compatible with the old version?
                  FreeBird
                    I will try to find it and send it over…
                    • F Offline
                      FreeBird @spwolf
                      Any news about this issue ?
                      FreeBird
                      • F Offline
                        FreeBird @FreeBird
                        Bump!
                        Anyone home???
                          i need to find that 2007 versions… stay tuned.
                            Here you go:
                            http://www.powerarchiver.com/test/alpha100/pa_10.22.02.u3p
                            check it out…
                            • F Offline
                              FreeBird @spwolf
                              Sorry, can’t download from the above link. I’m coming back to the default download page.
                              FreeBird
                                Sorry, wrong one:
                                http://www.powerarchiver.com/test/release100/pa_10.22.02.u3p
                                • F Offline
                                  FreeBird @spwolf
                                  Sorry, wrong one:
                                  Sorry, same problem.
                                  FreeBird
                                    probably then due to the older version of sdk we used for U3….
                                    It will be fixed in 11.5 release.
                                    • F Offline
                                      FreeBird @spwolf
                                      Ooops, sorry,
                                      what I meant is that the second link you posted is also not working.
                                      But don’t worry, I will wait for V11.5.
                                      Thanks anyway for your help
                                      FreeBird
                                        eh, sorry:
                                        http://www.powerarchiver.com/test/release10/pa_10.22.02.u3p
                                        • F Offline
                                          FreeBird @spwolf
                                          Hi spwolf,
                                          just tested the version you provided (10.22.02). Exactly the same problem as in version 11.03.03.
                                          Launcher.exe uses 50% CPU load on Vista Ultimate after removal of the U3 stick.
                                          So I’m waiting patiently for version 11.5 :)
                                          FreeBird
                                            ok… i have logged it in our bug tracking system already, it is just waiting for more time…
