    How to remove script scheduling…
    5 Posts 2 Posters 5.8k Views
    • J Offline
      Jockel
      If you have set script scheduling and want to cancel this and set to manual, there is no way to delete the scheduled task from within PA. Well, certainly I can delete the task from taskplaner. But, if I select manual instead of script scheduling, the the scheduling options are grayed out and make the user believe that all is set to manual now. This is a little irritating, you should remove the task, respectively, if this can not be done, display a warning/hint.
        where are you selecting manual? In latest release we have No scheduling option?
        • J Offline
          Jockel @spwolf
          I am with version 11.02.03 and with “scheduling Funktionen” (second last in tree) you see in the right pane, first option below “execute Script” section:
          “execute manually”
          If you select this, a task previously scheduled in taks-manager is not removed!
            it should be!!!
            (entered it to the bug list, thanks)
              this works properly - you need to use close button or run the script for task to be added or remove.
