    SFX CAB not handled by PowerArchiver 2009
    7 Posts 5 Posters 6.1k Views
    • J Offline
      joakim_46 Alpha Testers
      The following file is not handled by PA’s shell extension:
      http://download.microsoft.com/download/0/d/3/0d307649-9967-49fa-ab27-61f11024e97f/directx_nov2008_redist.exe
        extracted just fine using PA 11.02.03
        anyone else?
          64 bit or 32bit shell?
            TBGBe @Mili
            @Mili:
            anyone else?
            Works for me (Win XP SP3).
            • skypxS Offline
              skypx @TBGBe
              Working fine here with the latest version of PA and vista 64.
              ASUS Crosshair VII Hero
              AMD Ryzen 9 5700X
              T-Force DDR4 3600 32GB
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
              • J Offline
                joakim_46 Alpha Testers @skypx
                Yeah, sorry, did not had the latest build :D
