    Shell Extension
    8 Posts 2 Posters 7.0k Views
    • E Offline
      EricSch
      After some re-/install session, I gave up.
      PA2009 still shows no shell extensions under Vista or Win2008 64Bit. They are not shown in 64Bit and 32Bit applications.
      After some post seen in this forum, it seems to be a real problem.
      Is there a real solution?
        You mean that explorer replacement that is 32bit will not display 64bit PA shell extensions in 64bit OS?
        Or is it something else?
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          EricSch @spwolf
          You mean that explorer replacement that is 32bit will >>not display 64bit PA shell extensions in 64bit OS?
          Yes, but I have also no PA shell extension in 64Bit apps (Windows explorer).
          As example take TortoiseSVN:
          They suggest to install the 32Bit and 64Bit version.
          So I have the shell extension in 64 bit (ex. Windows Explorer) and 32 bit applications (ex. Servant Salamander) on a 64bit OS.
            you should have 64bit shell extensions in 64bit Windows Explorer… what version of PowerArchiver do you have?
            • E Offline
              EricSch @spwolf
              PA2009, latest build
                where is it installed to?
                We have no problems here, and many forum members use 64bit Windows as well…
                • E Offline
                  EricSch @spwolf
                  Installed to -> Default
                  Yeah, sure, because of that I found more than 3 post, where people mention the same problem.
                  But thanks anyway for your time
                    spwolf conexware @EricSch
                    @EricSch:
                    care to show me those posts? Those posts were about 32bit programs that cant display 64bit shell extensions - not PA shell not working in basic Windows Explorer. There are quite few users that use 64bit shell extensions here….
