    Problem with Profiles in PA2009
    3 Posts 3 Posters 3.7k Views
    • X Offline
      x_user
      when I try to add files into a new archive the profile option is greyed out (see pict attached). Am I missing something?
      OS: XP Pro
        davidsplash
        this is exactly what i get wehn adding files to an existing zip made already. what it seems you are doing is not creating a new zip but adding files to an existing zip that has the default zip profile. I can tell this by you using the add window. Whart you need to do is go to fil;e new on the tool bar and try again
          you need to setup profiles in config> compression profiles… and then you will be able to select which one you want to use… thanks
