    Extracting .exe archives via right click.
    4 Posts 2 Posters 6.5k Views
    • skypxS Offline
      skypx
      I noticed this before and I’ve addressed it a while back so please bear with me. I can extract .exe files with PA2009 if I first open PA2009, select open archive, and then select all files. From here I can extract the file without any issues, but the option is not available to extract it via right click (yes I looked in the shell extension options). Because of this I use WinZip 12. Can this option be added to PA2009?
      PA2009
      WinZip 12
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
        it actually depends on the .exe itself… send us url to the one that does not work, and we will add support for it… Not all SFX files are created equal…
        • skypxS Offline
          skypx @spwolf
          Cool, here is the link…. Thank you.
          http://www.nvidia.com/content/DriverDownload/download_confirmation.asp?url=http://us.download.nvidia.com/Windows/178.24/178.24_geforce_winvista_64bit_english_whql.exe
          AMD Ryzen 9 5700X
          Samsung 970 EVO 2TB
          GTX 3080ti
          Win10 x64
            Please try with this release:
            http://www.powerarchiver.com/test/release10/powarc1102.exe
            and let us know if it works.
