    Shell extensions not showing up
    2 Posts 2 Posters 4.0k Views
    • T Offline
      trparky
      When I right-click on a ZIP file none of the PowerArchiver options show up. They also don’t show up if I want to right-click on a file to compress.
      Operating System: Windows Vista Home Premium 64-bit
      PowerArchiver Version: 11.00.78 (09/2008)
        Please don’t be offended, but can we start with the “basics”?
        1. Is “Use explorer shell Extensions” activated under configuration/Shell extensions?
        2. Have you rebooted since installing PA?
        3. Are you using Windows Explorer or another application?
        4. Is this for ALL files/folders/archives or only a specific file/folder?
        5)Are you using “extended”/Unicode characters?
        (see http://www.powerarchiver.com/forums/showthread.php?t=3392 )
        1. Possibly try re-installing?
          (see http://www.powerarchiver.com/forums/showthread.php?t=3330 )
