    Power Archiver Terminates Without Warning
    • S
      shaggy
      If, when creating a spanned archive, the option “Write directly into ZIP” is set, no archive will be created, and no error message given; Power Archiver simply terminates and does nothing. My guess is that this option should be disabled when spanning, but I am not certain. This happens on both NTFS and FAT32 drives.
      System Configuration:
      Windows 2000 SP4
      Athlon XP 1700+
      1.5GB RAM
      • K
        klumy
        I can confirm this ;)
        • ivanI
          ivan conexware @klumy
          I suppose you tried creating from Windows Explorer via shell-extensions. The issue will be fixed in 9.1.
          • S
            shaggy @ivan
            Yeah, I use the explorer extensions almost exclusively.
