    Queue how does it work
    2 Posts 2 Posters 3.5k Views
    • MrAngelusM Offline
      MrAngelus
      ok simple question
      i have the PA 2009 starter in sys tray which I think you need to use queue
      I’m in the middle of extracting something
      How do I add or create a que if there’s several files
      there is no add to que option in context menu
      so what am I missing?
        simplest way is right click on PA Starter and check Always use Queue… otherwise, you have to go to options screen and check Add to Queue…
        should be quite useful for extracting/compressing several files at once, without slowing down your computer…
