    PowerArchiver 2009 Pro Burner
    7 Posts 2 Posters 7.7k Views
    • K Offline
      Keith Weisshar
      PowerArchiver 2009 Pro includes a CD/DVD burning utility. I already have Nero 8 installed. Is there a difference in the way they burn to CD/DVD?
        Generally speaking no, PA lets you burn within PowerArchiver, including PA Backup or while creating an archive, thus making 2 operations, one.
        It is also lightweight and quick…
        and I am moving this thread to general forums…
        • K Offline
          Keith Weisshar @spwolf
          This post is deleted!
            if you already have an burner, that you are happy with and dont need ability to burn within PowerArchiver (archive to disc or backup to disc or whatever other feature we have), then you dont need to use PowerArchiver Burner or buy it.
            • K Offline
              What size bootable image does the PowerArchiver burner support for the bootable option in the burner?
                spwolf conexware @Keith Weisshar
                @Keith:
                are you talking about disc image? there is no size restriction if you have bootable disc…
                • K Offline
                  It’s the boot image in the boot options. What size .img file does it have to be?
