    Backup problem Beta 5 German
    28 Posts 3 Posters 20.5k Views
      Daily option is one that can be customized to whatever you need…
        TBGBe @spwolf
        So how do I create a backup with following schedules -
        Today is Saturday 30 Aug 12:00
        1. Create weekly pbs to run at 06:00 on Thursday ?
        2. Create monthly pbs to run at 18:00 on 15th ?
        Only way I see is to change PC date/time??
          Please check RC1 via web update and let us know if everything works properly now.
          thank you!
            (meaning: if daily works)
            • T Offline
              TSchm @spwolf
              Has there been any modification in the actual release? RC1 shows the same bad behaviour as Beta5 on my computer.
                spwolf conexware @TSchm
                @TSchm:
                nope, there is no time for that - you can configure daily option to whatever you want and you should use that…
                we will improve on weekly/monthly in the first update after final is released…
                  Please try with final pre-release version:
                  http://www.powerarchiver.com/test/release10/powarc1100rc5.exe
                  And let us know if this has been improved right away.
                    p.s. confusion here was that Vista and XP schedule options are different - Vista’s worked ok, while on XP it did not (should work now when you click on Edit!)
