PA2009 Compression Ratio
I am a registered user and I’m using PA2009 Beta 5. I’m just curious about why when compressing some files & folders in PA2009 and compressing the same files & folders in 7-Zip would end up with different size files. I used ultra compression in both and used 7z as the archive type in PA2009.
PA2009 result: 19,256kb
7-Zip result: 16,779kbI still use PA2009 because it stores the relative folder info and 7-Zip does not (at least I couldn’t find that option in 7-Zip). I don’t think that the relative folder info alone would cause that much size difference. I’m not sure what the results would be with previous PA versions.
Any ideas?
BudmanWV
Welcome to PowerArchiver forums, Budmanwv!
Any ideas?
BudmanWV
there shouldnt be such difference - are you using Optimized? If so, turn it off.
In our testings, I have not seen difference than is bigger than 0.01%.
are you by any chance using queue? There was an bug in b5 where queue did not use the ultra settings for 7z.
I was not using the Queue. However, I was also not using the “Create Solid Archive” option. Using that option, I did the another comparison and here are the results:
PA2009: 16,796kb
7-Zip: 16,779kbThat is close enough for me. Thanks for the suggestions and help.
Budman
Hmm…Optimized Compression not so good…not so smart…
haha, what is not so smart about it?
http://www.powerarchiver.com/forums/showthread.php?t=3262
PowerArchiver tries to smartly detect files ```but after such smart compressed files size bigger then common -
and the compressin speed higher then common.](but after such [color]smart[/color] compressed files size bigger then common
and the compressin speed higher then common.) -
@NTFS:
may be so,
indeed
