    Extracting spanned archives not working with PA2009 B3
    11 Posts 3 Posters 9.3k Views
    • skypxS Offline
      skypx
      I remember reading a post stating this would be fixed in B3 but it’s not working with Vista 64.
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
        Thanks skypx!
        To help our dev team, can you post the error message? screenshot maybe
          @skypx:
          what spanned archives? 7zip? zip? rar?
          • skypxS Offline
            skypx @spwolf
            Sorry for the lack of information. The archives are .rar 200MB each (5 all together). I right clicked the last archive and selected “extract here”, the extracting window popped up for less than a second then vanished without extracting anything. No error messages at all. Thanks.
            AMD Ryzen 9 5700X
            Samsung 970 EVO 2TB
            GTX 3080ti
            Win10 x64
              spwolf conexware @skypx
              @skypx:
              is there possibility for you to check if same archive works on 32bit windows?
              need to see if it is due to shell ext, or something specific to archive?
              • skypxS Offline
                skypx @spwolf
                No, unfortunately all of our computers have Vista 64 installed. Sorry.
                AMD Ryzen 9 5700X
                Samsung 970 EVO 2TB
                GTX 3080ti
                Win10 x64
                  we will check it out then… this specific bug has not been reported before.
                  • skypxS Offline
                    skypx @spwolf
                    Thank you.
                    AMD Ryzen 9 5700X
                    Samsung 970 EVO 2TB
                    GTX 3080ti
                    Win10 x64
                      what is the filename that you right clicked on and didnt work? thanks
                      • skypxS Offline
                        skypx @spwolf
                        It was “encp09-xiso.part01.rar”.
                        AMD Ryzen 9 5700X
                        Samsung 970 EVO 2TB
                        GTX 3080ti
                        Win10 x64
                          please check with beta 4 now avail. through web update and let us know if this has been improved.
