PA 2009 Beta 3 and FreeCommander
PA 2009 Beta 3 (Shell Extensions) dont work with the last FreeCommander Build 2008.06a :mad:
I have just installed latest version of FreeCommander, and PowerArchiver shell extensions work correctly as from Windows Explorer. I don’t see any problems. Anyway if it works in Windows Explorer then it should work in any other application that has correct support for Windows Shell Context Menus.
Sorry, but it realy don’t work with Vista 64-Bit an FreeCommander!!
let me guess - it looks for 32 bit shell extension in 64bit Vista?
