    P
    Will you be releasing 2024 soon?
    PA 2023 Toolbox - 22.00.09 - Remove archive encryption
    PA_FanP
    Win 11 64 bit
    I have some archives which have been encrypted, using the encrypt option either in pbs or when interactively creating a zip. When I open these, and look at files, I am asked for passwords, which I know, and then can view items or decrypt the files in the archive (tools>decrypt files).
    However, when I use the Actions>Remove Archive Encryption (whether using the same zip or asking to write another), the routine shows progress bar to the end, but then just hangs i.e. “OK” never activates. All process information shows this stalled/hanging.
    What can I do to sort this out?
    PA2009 refresh issues
    4759
    • S
      Sakui
      I noticed when I use the office ribbon, the top of the window tries to exposes the default window XP titlebar.
      I can reproduce it when I first load it and move the cursor to the top of PA2009 pro 11.00.45 (07/2008), when you resize the window too small (ribbon is gone), you can’t really resize it back until you close and reopen it.
      Sakui
        it might be that your graphics card is not fast enough to repaint the buttons?
        what OS and graphic card are you using?
        I can reproduce this only when using standard windows drivers on Win2000 (which means very bad graphics performance)
        • S
          Sakui @spwolf
          I can tell you, it’s not the computer. I have an AMD Athlon64 X2 4400, 2gb of ddr400, geforce 6000 series. I have no issues on refresh rates on any other programs including windows XP.
            Cannot reproduce this on XP. Anyone else?
              mwb1100 @Mili
              I also do not repro this on WinXP SP2.
              I have found that often these types of display artifacts are often fixed by updating the display device driver or by going into the ‘Troubleshooting’ tab of the display adapter’s control panel settings and reducing the ‘Hardware acceleration’ setting.
                please check with beta 4 now avail. through web update and let us know if this has been improved.
