    PowerArchiver 2009 Pro Upgrade Order
    12 Posts 4 Posters 9.4k Views
    • K Offline
      Keith Weisshar
      I just ordered the upgrade to the pro version for $6.98 from the account. Why do I still have the standard version listed under Free Upgrades and an a upgrade button listed under Available Upgrades even after the order is completed?
        it doest remove those options, it just adds PA 2009 Pro in your account at special price… and thanks.
        • K Offline
          Keith Weisshar @spwolf
          Does the beta version expire and display a message to download a new version?
            nope
            • K Offline
              Will the Virtual DVD conflict with other Virtual CD software such as ISODrive included with UltraISO if installed at the same time? There is a Burner software included in the Pro version but I already have Nero.
                no it will not…
                • K Offline
                  Keith Weisshar
                  Should I uninstall the beta version before installing the final version when the final version is released?
                    no, there is no need to.
                    • K Offline
                      konic
                      Hi there.
                      I’m kind of confused, - under Free Upgrades I see PowerArchiver 2009 Standard,
                      but when I press this button I am moved to the Download page,
                      and there I see only PowerArchiver 2009 Beta 2 (!?)
                      So, where is release version of 2009?
                      Beta 2 is not even RC, so why am I asked to upgrade to it?
                        spwolf conexware @konic
                        @konic:
                        Hi there.
                        if you want to use PA 2009 Beta - which is actually already better than 2007, you need new codes.
                        So thats why it is there (click on resend codes to get PA 2009 Standard codes).
                        If you dont want to use PA 2009 until it is released, then… dont use it :)
                        • A Offline
                          aperry
                          I have a question about upgrades as well. I have one license purchased a while back. Can I order additional licenses at this time at the discounted rate? The order page seems to allow you to do it, but I wanted to make sure I wasn’t doing something wrong.
                            spwolf conexware @aperry
                            @aperry:
                            yes you can, and it is cheap as… well, something really cheap :)
