    Double Display of Folder Structure
    7 Posts 3 Posters 6.3k Views
    • B Offline
      bfschuil
      Hey,
      I went to update an archive through the shell interface (Created and archive w/ the same name, said yes to do you want up update this archive) and I got a really interesting result with the explorer view. It shows the folders twice.
      It’s too big to upload here but I put a copy here for you to check out: http://uploader.polorix.net//files/201/public/591RaytracingProject.zip
      Ben
      (PA 10.22, Vista SP1)
      • RJWaringR Offline
        RJWaring
        Interesting! :S
        • B Offline
          bfschuil @RJWaring
          any thoughts spwolf?
          • guidoG Offline
            guido
            download doesn’t work
            Windows 11 Pro ENU x64
            Intel Core I7
            32 GB RAM
            • RJWaringR Offline
              RJWaring
              I did download it but DOD shreded it soon after! Sorry… Can bfschuil re-source the file?.
              • B Offline
                bfschuil @RJWaring
                Hi Guys - I reuploaded it for you. It’s the same link as above
                • guidoG Offline
                  guido
                  This looks indeed like a bug. I guess Ivan will look at this and fixes it.
                  For some reason it also shows the foldername in lowercase.
                  Intel Core I7
                  32 GB RAM
