    7zip
    • D
      davidsplash
      thought everyone would like to know that using standard method for compression and then sfx a 7zip file would make it larger than a normal zip sfx file.
      • B
        By-Tor
        That would be dependent on the data compressed and the SFX stub used to make the SFX. ;)
        • D
          davidsplash @By-Tor
          i used the canterbury corpse the archive testing files.
          • B
            By-Tor @davidsplash
            It’s very dependent on the data then. Try the same with a nightly Firefox distribution and you’ll see a huge advantage for 7-Zip.
