    PowerArchiver has taken over. Please help.
    19 Posts 4 Posters 15.6k Views
    • G Offline
      grit
      PowerArchiver 2007 (most recent version) is installed on Vista 32 bit with all the updates. When I click a .zip from within Internet Explorer, the file is wisked away to an unknown temporary location and immediately opend up by PowerArchiver.
      I understand this is either a feature, or a function of how IE handles .zip files. What I CAN’T figure out is how to change or disable it. I want to download .zip files and save them. If PowerArchiver let me download the file and save it where I wanted, THEN opened it up, I might be ok with that.
      Regardless, after an hour of sifting through PowerArchiver settings (no context help to explain what everthing does?) and IE and Vista, I can’t fix this. Any help would be appreciated.
        It seems you set IE to Open files by default. It has nothing to do with PowerArchiver, other than it being default “editor” for file type you are downloading.
        Doesnt PA give you an option to save the file before you close it? That should help at least.
        Did you try going to IE> Tools> Internet Options> Advanced> Reset?
          What happens when you right click on the file and select Save target as?
          Thats how you get save prompt to pick where you can save the file (zip in this case).
          • G Offline
            grit @spwolf
            The right click to “Save As” does work. But before I installed PowerArchiver, .zip files got downloaded.
            I figured there was an option within Vista to change how it handles .zip file types, but I cannot find anything, just the fact that .zip is associated with PowerArchiver. What frustrates me is that it should NOT act that way with a hyperlink. Personally, I find that to be a security issue.
              By default, Vista shows you the dialogue to chose Run, Save, Cancel.
              It has to be some Internet Explorer option - it has nothing to do with associations.
              Did you try reseting IE options?
              • RJWaringR Offline
                RJWaring
                Agree with spwolf, It has nothing to do with PowerArchiver’s associations.
                Reset IE to default, also if you have any type of Browser Protection ie Firewall/Virus checker with file type handling processes check them aswell.
                It is possible and I know this from expereince with Avast! That when downloading certain files that pose a potential “security threat” ie Zip’s,CAB’s, Exe’s the firewal/virus scanner will scan during download and may move to a temp location ie Quarantine Folder untill sectioned as safe.
                • G Offline
                  grit
                  I can’t fix the problem. It did not exist until I recently updated PowerArchiver. And, when I uninstall PowerArchiver, everything goes back to normal.
                  I’ll try reinstalling one more time. But if it does it again, I think i’ll just uninstall it and leave it that way. I’m disappointed that this program changes how downloads are handled and it cannot be changed. I did not have this same behavior with either WinZip or WinAce.
                    spwolf conexware @grit
                    @grit:
                    Since it is not PowerArchiver doing anything, reinstalling it wont fix the issue.
                    Once again, did you try reseting IE options?
                    PowerArchiver does not influence what IE does, whatsoever nor it changes any of your IE settings.
                      So, here is what you did.
                      When you click on zip file in IE, it shows an window with 3 options: Open, Save, Cancel.
                      There is also an checkbox: Always ask for this file type.
                      You unchecked this checkbox. Which means now when you click on Zip (which is “PowerArchiver Zip File”), it will automatically Open the file.
                      I would think that reseting IE options would reset that choice as well.
                      • G Offline
                        grit
                        Can someone please tell me WHERE to find this option to reset it?
                        • RJWaringR Offline
                          RJWaring
                          Method 4: Reset Internet Explorer 7 settings
                          To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these
                          steps
                          1. Open Internet Explorer 7.
                          2. Click Tools, and then click Internet Options.
                          3. Click the Advanced tab.
                          4. Under Reset Internet Explorer Settings, click Reset
                          more information on how to resolve broswer issues can be found on
                          http://support.microsoft.com/default.aspx/kb/936213
                          • G Offline
                            grit @RJWaring
                            Ok, I followed the above directions, exactly. I even rebooted the computer. It did not change anything.
                            I think spitwolf was close when he posted this:
                            It’s not IE, it’s a Windows association thing. What action should windows take when you click on this file type. Those settings are made by the program. For example, if I install a new program that uses the .abc file type, the next time you click on an .abc file, the program will load the file, play the file, open the file for editing, etc. It all depends on how the program setup the associations.
                            I can edit them easily enough in XP, but I can’t seem to in Vista.
                            Other suggestions?
                            • RJWaringR Offline
                              RJWaring
                              At the momment I only use XP Pro SP2… my Vista Computer Blew up some time ago and have yet decided what computer to buy… So I cant help you sorry.
                              Does anyone using vista have an idea on this?
                              • LuxorL Offline
                                Luxor Alpha Testers @RJWaring
                                On my Vista Premium computer.
                                Start|Default Programs
                                Associate a file type or protocol with a program.
                                Find the file type and click on Change program.
                                Windows 10 Home 64-bit
                                • G Offline
                                  grit @Luxor
                                  @Luxor:
                                  That’ll let me pick a different program, but not how the program handles the file. In XP, thats where you can change the default action when you double click the file type.
                                  What I don’t understand is why this action is carried over into IE.
                                  spwolfS LuxorL 3 Replies Last reply Reply Quote 0
                                    @grit:
                                    I explained EXACTLY why this happened.
                                    Because in IE, you clicked on option to not show dialogue window anymore.
                                    Here is how to disable it in IE:
                                    http://www.ieinfosite.co.uk/tip_view.asp?id=112
                                      Here is the one for Vista:
                                      http://www.mydigitallife.info/2007/06/15/reset-always-ask-before-opening-this-type-of-file-check-box-in-vista-ie/
                                      • LuxorL Offline
                                        Luxor Alpha Testers @grit
                                        @grit:
                                        That’s all there is in Vista AFAIK
                                        Don’t know sorry. :(
                                        • G Offline
                                          grit @spwolf
                                          That did it! Thanks, you saved me! :D
