Problem with making the archive
The Dear friends!!! I long ago use your program (the version 10.11.01) - very complacent.
But recently appears the problem - try to create the archive with file having in name scandinavian transcription type Ä Ë å ï ò é and so on. The Files with such writing are skipped. Whence this problem and possible her(its) avoid? Respectfully yours Alexander. -
you need to set support for your language in Regional and Language Settings> Advanced in Control Panel.
Or you can use 7zip compression for unicode support.
