    Drag Drop Problem with PA 10.21 RC2
    4 Posts 3 Posters 5.3k Views
    • V Offline
      Vykranth
      I have a bizarre problem with PA 10.21 RC2. When I open an archive and I drag-drop elements of the archive to an explorer window, the extracted file are there but in a _PAxy directory (xy being a 2 digit number).
      This is the temporary folder in %TEMP% that is copied and not the actual files.
      OS: Vista x64 with a C: System Drive and a D: User Drive but I manage to reproduce it regardless on the position of the zip files: I get the problem when the archive is on C: or on D:.
      I cannot guarantee that this is new to RC 2: I don’t recall trying it with RC1.
      Vyk
        thanks, we will check it out.
          We tried reproducing the problem in .zip format and it works fine. Please let us know which format you used to archive your files.
          V 1 Reply Last reply Reply Quote 0
          • V Offline
            Vykranth @Mili
            I have retried it. I have found out that I was using 10.21.11. That would be RC1, right? I guess I made a mistake reporting
            the version number, sorry about that.
            I got the update to 10.21.12 and everything seems to be working fine with this one. The drag-drop does not give the temporary _PAxyz folders.
            You can close this thread.
            Vyk
