    Final RC interface issue
    3 Posts 2 Posters 3.7k Views
    • J Offline
      JohnS
      Hi: installed the latest RC over exisintg installation. Installed fine but the toolbar was partially corrupt. I had “Smooth Lime” already installed and this seemed to conflict with the modern toolbar. I managed to find the configuration button and set the skin to default but when I then tried to get Smooth Lime to function I would get toolbar corruption again. This hasn’t happend up this point. I then reset the default interface which worked fine and then I was to select the modern interface which also worked fine. But I could not get back into Smooth Lime without getting the confused toolbar situation again. Hope this was somewhat clear. John
        fixed in latest RC (just redownload)…
        • J Offline
          JohnS @spwolf
          Problem seems to be resolved. Thanks. John
