    Powerachives rar extraction not working
    12 Posts 4 Posters 8.9k Views
      davidsplash
      i had a rar file from aststalk.com full of mp3 files and powerarchiver could not extract it it contained 2 folders of files. The total size was 89 mb for the rar file.
      However 7zip file manager worked ok when will a fix come out for this
        Could you indicate where the rar file is on that site - so it can be checked/tested?
          spwolf conexware @TBGBe
          @TBGBe:
            davidsplash @spwolf
            Its Not Just One Particular Rar File It Is Several And As I’m Not On My Office Computer At Present I Can Not Get The File Back For Testing Though I Have Mention This Before That Pa Can Not Extract Rar Files That Are Part Of A Set Of Spanned Rar Files.
              spwolf conexware @davidsplash
              @davidsplash:
              Unless you send us an example, we cant check it out… I checked with several rar files and it worked just fine.
                davidsplash @spwolf
                http://rs108.rapidshare.com/files/45806442/VA_-_The_Sound_Of_Tuning_Summer_2007_2_Cd_s.part2.rar
                this file can be extrated by 7zip file manager but not pa even though only one file is a problem. When will u allow extraction of all good files like 7zip has done
                • A Offline
                  amh209
                  I downloaded the file and I also get the CRC error.
                    problem is that that file is part of multivolume set, thats why it doesnt work in PA. WinRar will extract what it can though, but PA can not do that right now.
                    If you had all of the multivolumes, it would work fine with PA as well.
                      davidsplash @spwolf
                      how comes the 7zip file manager can extract it?
                      cause they are upto date with rar extraction?
                      when will you recitfiy this
                        eh
                          davidsplash @spwolf
                          what i’m trying to say is that 7zip file manager can extract single rar files out of a spanned set so why can’t powerarchiver?
                          secondly i’m asking when will you be able to extract single rar files out of a spanned set with powerarchiver.
                            PA 2008? hopefully…
