    Problems with Outlook Addin Beta 4
    7 Posts 4 Posters 6.2k Views
    • T Offline
      timjstone
      I have been successfully using Beta 2 with Outlook 2007 but when i try to use Beta 4, when sending the mail, the compress window flashs up and the mail is sent without compressing. when reverting the beta 2 the compression happens correctly.
        what version of PA are you using?
        • T Offline
          timjstone
          PA 10.20.02.
          is there any other info you need
            spwolf conexware @timjstone
            what kind of attachment was it? (extension).
              TBGBe @spwolf
              Err … Beta 4 :confused:
              Do you mean Beta 3 (V2.00.06) or have I missed an unannounced update?
              • T Offline
                timjstone
                I tried it with various attachments, PDF and XLS. For another reason, i re-installed my machine from scratch and then reinstalled office, powerarchiver and the addin. Beta 4 showed the same problems (compress window flashing up quickly and not compressing the file). i suspect it is not finding powerarchiver or there is a problem in the transmission of the parameters.
                • A Offline
                  amh209 @timjstone
                  PowerArchiver Outlook Plug-In 2.0 Beta 4 (for Vista and Office 2007)
                  Allows for automatic compression of all
                  outgoing attachments in MS Outlook. (From the download page)
                  Yep, TBGBE, you missed one.
