    Problems with v10.20 beta 1 and Vista 64
    11 Posts 4 Posters 7.8k Views
    • skypxS Offline
      skypx
      I downloaded and installed (clean install/restarted) v10.20 beta 1 and I get the following error when exiting the program. The text file has the error message from the problems reports and solutions applet in the control panel.
      attachment_t_2549_1_problems-reports-and-solutions.txt
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
      • skypxS Offline
        skypx
        I have reproduced this error on two systems running Vista 64. Anyone else experiencing the same problem? Thanks.
        AMD Ryzen 9 5700X
        Samsung 970 EVO 2TB
        GTX 3080ti
        Win10 x64
        O 1 Reply Last reply Reply Quote 0
          goodies
            spwolf conexware @spwolf
            email us via support form please and we will send you test version…
            • skypxS Offline
              skypx @spwolf
              Support form sent! :)
              AMD Ryzen 9 5700X
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
              • skypxS Offline
                skypx
                I get the same error after using the new .exe.
                AMD Ryzen 9 5700X
                Samsung 970 EVO 2TB
                GTX 3080ti
                Win10 x64
                • skypxS Offline
                  skypx @skypx
                  I’m getting the same error with beta 2.
                  AMD Ryzen 9 5700X
                  Samsung 970 EVO 2TB
                  GTX 3080ti
                  Win10 x64
                  • O Offline
                    ohiodigiworks @skypx
                    @skypx:
                    Yep… I’m getting the same error using Vista x64 and PA Beta 2.
                    Mike Rickman
                      ivan conexware
                      Please check with Beta 3 preview:
                      http://www.powerarchiver.com/test/release10/powarc1020b3.exe
                      and let us know if it works properly now.
                      skypxS O 2 Replies Last reply Reply Quote 0
                      • skypxS Offline
                        skypx @ivan
                        Beta 3 is working great! Thank you. :D
                        AMD Ryzen 9 5700X
                        Samsung 970 EVO 2TB
                        GTX 3080ti
                        Win10 x64
                        • O Offline
                          ohiodigiworks @ivan
                          @ivan:
                          Yep… the Beta 3 release is working for me as well.
                          Great job!! :)
