    First install: wrong interface
    5 Posts 3 Posters 4.9k Views
    • B Offline
      bugfix
      Installing for the first time PA 10.10.10 and also 10.10.13, on a fresh machine PA asks for the interface to use.
      If I select “Modern ribbon” the interface doesn’t change and the next time I use PA the interface is always the “Classic windows”.
        thanks - we will check it out…
          ivan conexware @spwolf
          It will be fixed in 10.11. I wonder how noone notieced this in 10.10:)
            Please check with 10.11 release:
            http://www.powerarchiver.com/test/release10/powarc1011.exe
            And let us know if it works fine.
            thank you!
            • B Offline
              bugfix
              Seems fixed ;-)
