    Next volume question - text glitch
    8 Posts 3 Posters 8.6k Views
    • guidoG Offline
      guido
      there is no space between. “next volume:” & the filename.
      See image.
      At the moment it’s not really a question. I know what to do, but for someone who doesn’t, the question is not really clear.
      Guido
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
      • guidoG Offline
        guido
        Also check out the O&O part that is converted to just OO
        Guido
        Intel Core I7
        32 GB RAM
        • C Offline
          crunch
          Yes, I see it’s actually putting OO, which means that it’s programatically parsing the ampersand and creating an underlined keyboard shortcut. Try pressing Alt+O and let’s see what happens :D
            spwolf conexware @crunch
            @crunch:
            maybe format the hard drive?
            or
            wash the laudry?
            We will never know…
            • C Offline
              crunch @spwolf
              or
              wash the laudry?
              We will never know…
              :p
                please check with latest internal release:
                http://www.powerarchiver.com/test/release10/powarc1010.exe
                and let us know if it works properly now.
                • guidoG Offline
                  guido
                  The space is fixed. The double OO is not. And we have a new problem.
                  Now the message is:
                  Insert volume(-1): e:\Filename…
                  Why the -1?
                  And final. It still doesn’t do the laundry
                  Intel Core I7
                  32 GB RAM
                  • C Offline
                    crunch @guido
                    I think you have to choose between:
                    a) the one that does the laundry
                    b) the pretty one
                    or maybe
                    c) if you have enough money perhaps you can afford both
