    Problem extracting bin files in Vista 32 biy
    3 Posts 2 Posters 4.7k Views
    • P Offline
      pronam
      All files are extracted are of 2 KB size.
        hi,
        this is an known issue. PA’s ISO support currently does not support those files.
        • P Offline
          pronam @spwolf
          hi,
          Also I converted it to a .nrg file using nero, PA still has the same problem. Could you suggest any other tool that could convert it to a format that PA could recognize and work with?
