    Scheduled Task FTP Problem
    8 Posts 2 Posters 7.8k Views
    • J Offline
      JeffBelt
      Hi
      I have configured a backup job in PA2007 which i can run from windows explorer, it appears to work and FTP’s the created zip file to the target FTP folder.
      However, when i schedule the task with windows scheduler the FTP only works if the task is executed by the primary domain administrator account.
      I have used several other accounts, one of which had domain admin privileges (but not the main administrator account), and all of them create the zip file but leave it in the target directory and do not complete the FTP.
      From what i can see from the FTP server no connection is even attempted.
      Jeff
        that sounds really weird… we will check it out for .02 and let you know…
        thank you!
        • J Offline
          JeffBelt
          Hi
          Any progress on this?
          Jeff
            we are scheduled to start work on .02 over the weekend, so we will let you know after that.
              Hi Jeff,
              what OS are you using?
              • J Offline
                JeffBelt
                Windows 2003 x32 STD SP1
                Jeff
                • J Offline
                  JeffBelt
                  Any more progress on this?
                  Jeff
                    We will be working on it next… thanks jeff.
