    PA queue problem
    9 Posts 4 Posters 7.6k Views
    • P Offline
      pbru
      hi,
      in ‘options > queue’ I selected ‘always use queue’. then in the explorer, I selected a lot of .zip files ans asked to unzip. they went into the queue but for some unknown reason (maybe to many files in the queue?) the queue manager crached.
      now I can no longer use the queue manager as PA starter crach again and again.
      how can I empty the queue ?
      TIA,
      Pierre
        nice… how many zips did you add?
        • P Offline
          pbru @spwolf
          I had 192 ZIP to uncompress, and I visually (in the explorer) selected about 1/4 of them. PA starter started to open/add them in the queue but crached after about 10 of them.
          I run WinXPSP2 with the lastest patches.
            ivan conexware @pbru
            To empty queue you have to open Registry editor, open key HKEY_CURRENT_USER\Software\PowerArchiver\Queue
            and set the value of “NrQueues” to 0 (zero).
            • P Offline
              pbru
              thanx a lot :)
              BTW, I also removed all the queues entries
              • C Offline
                cswake
                I encountered a similar problem:
                This resolved it. Perhaps the next minor upgrade can include some sort of check to prevent this?
                  spwolf conexware @cswake
                  @cswake:
                  it will be fixed so it works with hundreds of files…
                    ivan conexware @spwolf
                    The limit of queue should be fixed in 10.1.
                      Please check prerelease version 10.1 B1:
                      http://www.powerarchiver.com/test/alpha100/powarc1010b1.exe
                      And let us know if this fixes your issue.
                      thank you!
