    Vista 64 and right-click drag
    30 Posts 7 Posters 24.8k Views
    • skypxS Offline
      skypx @skypx
      @skypx:
      I restarted the computer after the installation, but I did not do a clean install. I will and report the results.
      I uninstalled, restarted, installed, restarted, and unfortunately I still have the same options previously mentioned. Do I need a special tool to perform a clean install?
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
        you still only get extract here option?
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          Uvi @spwolf
          With the test version posted above and Vista x64 I now get Extract Here and Extract To options with a right click and drag operation.
          • K Offline
            Kenneniah
            Same. Version 10.01.03 is now giving me the “Extract Here” and “Extract To” options so I’m happy.
              spwolf conexware @Uvi
              @Uvi:
              that is what you should get…
              • skypxS Offline
                skypx @spwolf
                I’m sorry to say that it’s not working as it should. The “Extract here” and “Extract to” options will extract all files to the same location. There is no option to extract a zipped folder to another folder within the target location. So if you right click and drag a folder named “files” to the e: drive, it will only extract the contents to the root drive and not to a folder called “files”.
                AMD Ryzen 9 5700X
                Samsung 970 EVO 2TB
                GTX 3080ti
                Win10 x64
                • W Offline
                  wallan37
                  I have the same issue as skypx, always extracts to the root directory. I am on day 25 of my trial and so far I am not convinced to buy :(
                    spwolf conexware @wallan37
                    @wallan37:
                    you should definetly be very happy with it if you are considering purchasing….
                      spwolf conexware @skypx
                      @skypx:
                      I’m sorry to say that it’s not working as it should. The “Extract here” and “Extract to” options will extract all files to the same location. .
                      ok
                      • H Offline
                        Henry_Jones @spwolf
                        The german version 10.01.03 is not displaying the drag’n drop menu at all, like the version before.
                        With the english version I’ve the same issue as wallan37 and skypx.
