    Vista 64 and right-click drag
    30 Posts 7 Posters 26.6k Views
    • K Offline
      Kenneniah
      I’m running Vista 64 on my desktop, and right-click dragging does not work. After dropping all I get is the default Windows context menu for extracting using its built in support. A normal right-click without dragging does bring up the PA context menu however. On my Vista 32 bit laptop, right-click dragging does work fine. Something with the drop handler and 64 bit maybe?
        64bit shell extension is completly different dll… check with 10.01 release and see if that helps.
        • skypxS Offline
          skypx @spwolf
          FYI version 10.00.39 has the same issue. Patiently awaiting version 10.01. :)
          ASUS Crosshair VII Hero
          AMD Ryzen 9 5700X
          T-Force DDR4 3600 32GB
          Samsung 970 EVO 2TB
          GTX 3080ti
          Win10 x64
            you guys can be creative with the download link while we wait for the website to be updated…
            • K Offline
              Kenneniah
              Still no change. Uninstalled old version, rebooted, downloaded and installed new version (says 10.00.42), and rebooted. Still just get generic Windows menu when dragging archives.
              • skypxS Offline
                skypx @Kenneniah
                @Kenneniah:
                :eek: Thanks for the heads up. I was really looking forward to finally getting this fixed.
                AMD Ryzen 9 5700X
                Samsung 970 EVO 2TB
                GTX 3080ti
                Win10 x64
                  sucks, it will be in for the next update…
                    ivan conexware @spwolf
                    Can you please try this:
                    Go to PowerArchiver’s installation folder (c:\program files\PowerArchiver) and run _PASETUP.EXE.
                    If it still doesn’t work I will make .reg file for you that will fix the problem - i think the problem is only with registry, but I am not sure why this happneds after installation when all registry entries are correct.
                    • skypxS Offline
                      skypx @ivan
                      @ivan:
                      Tried what you suggested, did not work.
                      AMD Ryzen 9 5700X
                      Samsung 970 EVO 2TB
                      GTX 3080ti
                      Win10 x64
                        2nd Try:
                        http://www.powerarchiver.com/test/release10/powarc1001.exe
                        Let me know if it works…
                        skypxS spwolfS 2 Replies Last reply Reply Quote 0
                        • skypxS Offline
                          skypx @spwolf
                          2nd Try:
                          Downloading now. :)
                          AMD Ryzen 9 5700X
                          Samsung 970 EVO 2TB
                          GTX 3080ti
                          Win10 x64
                          • skypxS Offline
                            skypx @skypx
                            @skypx:
                            Downloading now. :)
                            All the options are not there yet.
                            AMD Ryzen 9 5700X
                            Samsung 970 EVO 2TB
                            GTX 3080ti
                            Win10 x64
                              spwolf conexware @skypx
                              @skypx:
                              so there are more now?
                              • skypxS Offline
                                skypx @spwolf
                                Yes, basically the “extract here” option is available.
                                AMD Ryzen 9 5700X
                                Samsung 970 EVO 2TB
                                GTX 3080ti
                                Win10 x64
                                  ivan conexware @skypx
                                  The issue should be fixed in 10.01.01. Thanks!
                                  • skypxS Offline
                                    skypx @ivan
                                    @ivan:
                                    Cool!!!:)
                                    AMD Ryzen 9 5700X
                                    Samsung 970 EVO 2TB
                                    GTX 3080ti
                                    Win10 x64
                                      spwolf conexware @spwolf
                                      2nd Try:
                                      you can try it again…. it is new version.
                                      • skypxS Offline
                                        skypx @spwolf
                                        No change. I only have the option previously mentioned.
                                        AMD Ryzen 9 5700X
                                        Samsung 970 EVO 2TB
                                        GTX 3080ti
                                        Win10 x64
                                          You must restart computer because the DLL must be replaced. Maybe also try with clean install?
                                          • skypxS Offline
                                            skypx @ivan
                                            @ivan:
                                            I restarted the computer after the installation, but I did not do a clean install. I will and report the results.
                                            AMD Ryzen 9 5700X
                                            Samsung 970 EVO 2TB
                                            GTX 3080ti
                                            Win10 x64
