PA10 Bug: KB or MB sizes won't be shown within in archive
PA10 Bug: KB or MB sizes won’t be shown within in archive
a bit more explanation please? thanks
you mean size is set to be seen in bytes?
at the image you just see
winrecorder.ini 468
it should be
winrecorder.ini 468 Byte
or 0,4 kB
just add the KB to it
ok, so bytes is not written… we will probably change it to KB for future releases, makes more sense… thanks for the tip
good ;)
