PA10: Navigation via adressbar is not possible
Navigation via adressbar is not possible, like in the windows explorer
you must always use the archive folder bar
can this be changed?
Hi Masu,
thanks for all the threads :-).
Ok, so what exactly do you mean? can you explain or upload an screen shot since it works fine here, at least I think it does…
Download latest version (english only) via website or via web update and see if this issue has been fixed.
doesn’t work
so you select an folder and it doesnt work?
Works fine for me… anyone else?
still doesn’t work
and it is important that I try to navigate with the aderssbar !! like displayed in the image
works fine here, someone else please try it so we can figure it out…
I figured out a situation when there was no left-pane-tree and it will be fixed in 10.01.
great thanks
