    Right clicl 'Extract to' missing in PA7 10.00.36?
    12 Posts 3 Posters 6.3k Views
    • B Offline
      Bobsen
      Hi all,
      Am I missing something? Prior to upgrading to the new version of PA it was possible to right click and extract, now this option seems to be missing. Forgive me if this has been asked before but the ‘search this forum’ option does not seem to work with Firefox….
      Regards,
      Bobsen
        did you restart your computer after PA 2007 installation?
        • B Offline
          Bobsen @spwolf
          Yes a couple of times actually, I only first noticed the problem today (I upgrade the other day and hadn’t used PA since then).
          Regards,
          Bobsen
            easiest way to “fix” it would be to try to uninstall PA 2007 and then install it again… that will delete all the settings and it should work afterwards.
            • skypxS Offline
              skypx @spwolf
              I’ve been experiencing a similar problem with the latest version of PA and vista. If I right click and drag a compresses file to another folder I do not get option to “extract here etc” If I try the same thing in XP, it works ok, but in vista the option is not there. Am I missing something? Thanks.
              ASUS Crosshair VII Hero
              AMD Ryzen 9 5700X
              T-Force DDR4 3600 32GB
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
                spwolf conexware @skypx
                @skypx:
                i just tried it and it seems to work fine, same as in XP. Original poster didnt get any shell extensions.
                Maybe it is some option set differently or something a bit more specific in your case…
                • skypxS Offline
                  skypx @spwolf
                  That’s strange, I’ve looked at all the shell extention options and I can’t seem be able to fix this issue. I wonder if it makes a difference when using the 64bit edition?
                  AMD Ryzen 9 5700X
                  Samsung 970 EVO 2TB
                  GTX 3080ti
                  Win10 x64
                  skypxS spwolfS 2 Replies Last reply Reply Quote 0
                  • skypxS Offline
                    skypx @skypx
                    @skypx:
                    I also uninstalled the old version before installing version 10.00.36
                    AMD Ryzen 9 5700X
                    Samsung 970 EVO 2TB
                    GTX 3080ti
                    Win10 x64
                    • skypxS Offline
                      skypx @skypx
                      After uninstalling and reinstalling, I am experiencing the same problem. (Yes, I restarted after the uninstall)
                      Is the issue worth investigating?
                      AMD Ryzen 9 5700X
                      Samsung 970 EVO 2TB
                      GTX 3080ti
                      Win10 x64
                        @skypx:
                        there you go - 64bit edition has completly different shell extensions, so this feature was never added there… I will put it on the list for future updates.
                        • skypxS Offline
                          skypx @spwolf
                          Cool!! Thanks. :)
                          AMD Ryzen 9 5700X
                          Samsung 970 EVO 2TB
                          GTX 3080ti
                          Win10 x64
                          • B Offline
                            Bobsen @skypx
                            Uninstall/ reinstall did the trick thanks for the quick response. :)
                            Regards,
                            Bobsen
