    PA shortcuts in right-click context menu
    6 Posts 4 Posters 6.1k Views
      mkadmin
      This is how my explorer context menu looks after installing PA:
      How di I clean up this menu? I have removed all options under Configuration –> Shell Extensions but it hasn’t helped.
      Also how can I group all shortcuts similar t9o the Send To menu?
        you need to restart your computer so new shell extensions are installed…
          mkadmin @spwolf
          Works now after restart.
          also what abt my second query:
            @mkadmin:
            Also how can I group all shortcuts similar to the Send To menu?
            Do you mean - add them to the Sub-Menu ?
            You can do this for all EXCEPT “Compress with Options…”.
            Note: Remove from the Menu first then Add to Sub-Menu (can CTRL-Click to select multiple).
              Compress with options should be fine now…
              Download latest version (english only) via website or via web update and see if this issue has been fixed.
              • C Offline
                cyberblob @spwolf
                This post is deleted!
