    Plugins help
    8 Posts 3 Posters 5.7k Views
      davidsplash
      no help in the pa help file on how to install plugins trail and erro led me to the right way
        @davidsplash:
        double click on plugin and click Yes when it asks you to install?
          TBGBe @spwolf
          Then add the file type (extension) with the ‘.’ - this has changed :D
          However I agree with davidsplash - this should be covered in the help file
          D 2 Replies Last reply Reply Quote 0
            davidsplash @TBGBe
            this is not covered in the help file how to download plugins as firefox just displays them as rubbish on the screen instaed of downloading them.
              davidsplash @TBGBe
              added this to the same thread as this really should be mentioned in the help file on how to download them and especally as firefox has problems see below
              this is not covered in the help file how to download plugins as firefox just displays them as rubbish on the screen instead of downloading them. internet explorer downloads them ok when u click on them.
                TBGBe @davidsplash
                I think it is a server config problem.
                The PA Plug-ins page seems to be configured to provide the ppf files as “text/plain” - hence browsers try to display them.
                  works fine here?
                  In any case, Save target as will work fine everywhere.
                    TBGBe @spwolf
                    works fine here?
                    Yes, well that just identifies you as an IE user :D
                    Yes, “save target as” works - once you know what the problem is.
