    PowerArchiver 2007 Problem
    7 Posts 4 Posters 6.5k Views
    • Z Offline
      zipmeister
      Get this after indexing all compressed files on my PC with PA 2007 when pressing “options” button:
        Is this the same as
        http://www.powerarchiver.com/forums/showthread.php?t=2227 ?
        • I Offline
          illuzi0n @TBGBe
          hmm strange as everytime i run powerarchiver 10.0 final it auto restarts my computer even though im running on windows xp sp2
          need help asap…thanks
            spwolf conexware @illuzi0n
            @illuzi0n:
            Did any previous 10.00 versions work?
            • I Offline
              illuzi0n @spwolf
              i tried RC1 and also didnt work :( ….
                @illuzi0n:
                if you reported it at the time of RC1…
                In any case, please email support via support form, so we can send you some test cases to check and determine the cause of the issue.
                  Download latest version (english only) via website or via web update and see if this issue has been fixed.
