    Links for v2007..?
    9 Posts 2 Posters 7.2k Views
    • manuangiM Offline
      manuangi
      hello mates, I just installed v10.00.36
      apart from my notes, I’d like to ask if anyone has a direct link for the download…as it’s not the usual
      h*tp://dl.powerarchiver.com/xxxxx.exe
      I forgot to trace it with WireShark as usual :p
      Thank you!
      • manuangiM Offline
        manuangi
        ok, found ;)
        http://dl.powerarchiver.com/2007/powarc1000.exe
          Hi Angelica,
          Get the link from
          http://www.powerarchiver.com/download
          (direct is different for each language).
          P.S. welcome back :p
          Edit: Too late
          manuangiM 1 Reply Last reply Reply Quote 0
          • manuangiM Offline
            manuangi @TBGBe
            thank you, it’s that the links I can get from there have not been updated yet, and refer to v10 RC1 ;)
              TBGBe @manuangi
              Links for 2007 RC1 (English and German) are there :confused:
              • manuangiM Offline
                manuangi
                what have I written? I know RC1 is there…but the newest version is 10.00 final, no more RC…
                10.00.36
                  TBGBe @manuangi
                  @manuangi:
                  .but the newest version is 10.00 final, no more RC… 10.00.36
                  Careful, not yet announced - so not yet “final” :p
                  • manuangiM Offline
                    manuangi
                    how long to see the italian version online?
                      TBGBe @manuangi
                      Maybe you could help out
                      http://www.powerarchiver.com/forums/showthread.php?t=2281
                      :D
