    PA 2007 RC1 installed over top of 9.64.03
    5 Posts 2 Posters 5.1k Views
    • Brian GregoryB Offline
      Brian Gregory Alpha Testers
      I installed PA 2007 RC1 over the top of my old 9.64.03 installation.
      Is this allowed?
      I notice there are still some 9.64 related files in “C:\Program files\PwerArchiver” (such as the help file, numerous text files).
      Also in my Control Panel -> Add/Remove programs there are now entries for both versions of PowerArchiver.
        sure… but you will end up with what you ended up with :-).
          Brian Gregory Alpha Testers @spwolf
          So what do you recommend I do to tidy up?
            First uninstall PA 2007, then uninstall PA 2006 (in that order!), and then install… PA 2007.
            Although it shouldnt matter much…
              First uninstall PA 2007, then uninstall PA 2006 (in that order!), and then install… PA 2007…
              Thanks, will do.
