    Small problem when extracting some subs
    18 Posts 4 Posters 12.7k Views
    • C Offline
      Cristian
      I have some subs which can’t be extracted using the right click options. They can be extracted though if I double click on the archive and extract each one manually. I could upload them if it’s neccesary.
        “subs” :confused:
        Did you create these yourself or download them?
        Which format are they?
        • C Offline
          Cristian @TBGBe
          Subs = subtitles
          I’ve downloaded them, of course. :o
          They are in .idx/.sub format.
            TBGBe @Cristian
            Ah - ok.
            The only subtitles I have seen were compressed with either Zip or RAR.
            Sorry, but I don’t know or have any files with .idx/.sub formats.
            Maybe spywolf does know these.
            He can say if a link / upload would help.
            PS which version of PA are you using?
              you have to attach one example so we can check it out… thanks
              • C Offline
                Cristian @TBGBe
                I have the latest beta.
                There are a lot of subs of this type on the Internet, you’ll only need to look in the right places. :) I have no problems in general with this kind of files, this is a particular situation, I think.
                As I’ve said in previous post, I could upload them somewehere, file size is small.
                • C Offline
                  Cristian @Cristian
                  Done: http://file2upload.com/file/21778/tlsf-subs-part-rar.html
                    it is because of the name… we will check it out…
                      please check with beta 10… thanks
                      • C Offline
                        Cristian @spwolf
                        I’ve updated to beta 10 but the problem is still there: I can extract now the 2 files from the archive but I’m getting the same error when trying to extract the file particle.rar.
                          Can you upload that file as well?
                          • C Offline
                            Cristian @spwolf
                            It’s the same file. :)
                            The problem appears when trying to extract name.xvid.particle.rar
                              what exactly doesnt work? I can both open in inside of original archive and extract it as well?
                                sorry, got it…
                                • C Offline
                                  Cristian @spwolf
                                  Oops, we posted in the same time. :)
                                    ivan conexware @Cristian
                                    The issue should be fixed in Beta 11.
                                      please check with RC1… thanks
                                      • C Offline
                                        Cristian @spwolf
                                        Corrected. :)
