    Encryption Default from Shell Extension
    4 Posts 3 Posters 4.4k Views
    • K Offline
      kengrubb
      Can the Default encryption method be changed when encrypting a file via the Shell Extension? Rijndael 128 is always selected, but I use Rijndael 256.
      Thanks,
        yes, check Configuration> Compress & Encrypt, if you mean Compress and Encrypt shell extension?
        • K Offline
          kengrubb @spwolf
          My bad. I was referring to the Encrypt only option for an archive file.
            ivan conexware @kengrubb
            Saving of last used method from shell extensions will work in Beta 9.
            P.S. It works from Main PA Interface.
