    How does PA 07 work on Vista?
    26 Posts 4 Posters 16.6k Views
    • J Offline
      jowood @spwolf
      yep… except that UAC doesnt allow for runtime elevation of rights, so you end up with having to redesign how you do everything because of it…
      Try to copy a file with Explorer to the program files dir. Explorer requests elevation and the operation continues.
        spwolf conexware @jowood
        @jowood:
        as an different process…
        • J Offline
          jowood @spwolf
          No. Open the task manager and you will see, that no additional explorer.exe is launching…
            @jowood:
            you can elevate com objects, you cant elevate process… You can check it out on MSDN if you wish.
            This is done so virus or spyware cant elevate itself half an hour after you clicked on it, and then show you false name in the prompt…
              p.s. we can do that too anyway, it is just not an 5 minute job of elevating the process, rather you have to rewrite how application creates and extracts files (do it outside main PA process).
              • J Offline
                jowood @spwolf
                Cool, than you have to work with elevated COM objects. :)
