    Beta7: PA is german, shell is english
    10 Posts 3 Posters 6.7k Views
    • N Offline
      nfs_champ
      hello
      i installed 2007beta7 german.
      pa2007 is in german, but the shell extentions are in english. and i find no way to change that.
      any idea?
        did you restart computer after installation?
        • N Offline
          nfs_champ @spwolf
          yes, i restarted my computer.
            spwolf conexware @nfs_champ
            do you have 3 .plf files in \translations folder? And do you have any previous version installed?
            • N Offline
              nfs_champ @spwolf
              the folder is called “languages” and it contains 3 .plf-files (pashell_g.plf, …).
              i had pa 9.62 german installed. the next version i installed was 10beta6 and now 10beta7. i installed the new version in the same directory. following the text shown by the installer, the installer removed the old version befor installing the new version.
              thanx for yout help.
                can you remove PA 2007, and then remove PA 9.6xx… and then install PA 2007?
                • N Offline
                  nfs_champ @spwolf
                  removed 2007
                  removed 9.6
                  reboot
                  installed 2007
                  reboot
                  no change, still english.
                    thanks, I will check it out better on our computers and let you know…
                    • N Offline
                      nfs_champ @spwolf
                      thanx. till then i will go back to 9.6.
                        ivan conexware @nfs_champ
                        The issue should be fixed in Beta 8.
