    PA 2007 Beta 6 - small "highlight archive" issue
    3 Posts 2 Posters 4.0k Views
      mwb1100
      In PA 2007 Beta 6: some GZip files are not highlighted even if they are associated with PA. (Explorer view with highlighting enabled, of course).
      “.Z” files are not highlighted.
      “.gz” files are highlighted.
        ivan conexware
        The issue should be fixed in Beta 7.
          mwb1100
          Fixed in Beta 7.
