    Shell Extensions options
    8 Posts 4 Posters 6.8k Views
      snarfo
      First off–- in the options dialog for the shell extensions, it would be handy to be able to double-click to add or remove an item instead of clicking on each one individually then ‘add’ or ‘remove’.
      Secondly, and don’t forget to eventually Vistafy the PA program window’s close/maximize/minimize buttons :)
      Third, Keep up the great work!
        @snarfo:
        it should be multi-selectable, it will be. Dblclk wont work since there are two options (add and add to submenu)…
          and thanks :-)
            TBGBe @spwolf
            How about double click for removing (only)?
              spwolf conexware @TBGBe
              @TBGBe:
              wouldnt that be inconsistent? And how often do you change those options anyway?
                TBGBe @spwolf
                Not really, as remove only has one action (no worries about menu/sub-menu).
                Almost every time I am testing/playing with the beta :p
                However, with a release version, I agree it would be used very infrequently.
                  ivan conexware @TBGBe
                  Terry,
                  The multiselect option already works - try with CTRL key (not with Shift).
                    TBGBe @ivan
                    @ivan:
                    Beta 6 - :cool: :D
