Pa 2007 B8 shell extension error
The PA shell extension on Vista shows in the last row an empty field under the Power Archiver 2007 menu.
can you attach the screenshot?
thank you!
Here it is… Hope its helpful…
did you customize shell extension settings? If so, maybe you can attach PA registry zipped so we can use the same settings as you… (make sure you delete your reg key if you have it)…
What do you mean with PA registry? The complete Vista reg oder just the PA Part out of the Software part in the registry?
I didn’ customize the shell extensions…Alex
Just PA of course:
HKEY_CURRENT_USER\Software\PowerArchiverzip it after exporting and you can email it to us: support @ conexware . com
It is Vista x64 bit extensions btw, which are completly different code than 32bit, so we will check it out there…
Thank you… Sounds good…
So I guess it can be fixed…
Yes, it should be fixed in Beta 9.
please check it out with B9 and let us know.
thank you!
Looks good now!!
Great work!! Thank you!!
